Pulsar 220 DTSi ? 17 Known Problems and It?s solutions
6 replies to this topic
#1 ch.madhur
ch.madhur
  • 244 posts
Posted 17 February 2011 - 11:00 AM
By Saad Khan..One excellent review there on bikeadvice....would be helpful to all...
Issue No 1:. My Bike?s fairing rattles
Now this issue deserves the numero uno spot because of the ease it is found. Many people have started living with it. The bad part is that this was one of the highest reported issues on the DTS-Fi variant as well; however Bajaj was unable to fix that.
Solution:
1: Open the fairing and check whether all the rubberized joints and mountings have rubber rings present on them. If not, put one on all.
2: Put double sided tapes on all the places where the fairing touches any other part of the bike?s body.
3. Tighten the oil cooler plastic covers which have ?oil cooled? written over them. This is generally neglected and is one big culprit in creating that sound.
Issue No 2: My bike doesn?t start on mornings.
This is the cold starting problems generally associated with bikes. Pulsar 220 comes with an auto-choke which gets activated when the temperature sensor sends signals of activation when the engine is cold (generally happens in cold mornings when the bike?s engine has become cold due to overnight non-use), so this should not be as frequent on this bike.
Solution:
1.In case your bike suffers from this issue, get its temperature sensor checked for malfunction. Also check for the auto choke?s functioning and verify if it is working fine.
Issue No. 3: My bike wobbles at high speeds
Solution:
a) Get your bike?s alignment checked.
:) Also check that your Rims should not be bent and your tires should have adequate treads and pressure.
c) Cone set might also be one culprit, get it checked.
Issue No 4: My bike leaks oil from the block or cylinder head
This has been reported by many owners who have used higher quality synthetic oils like Motul 300V.
Solution: Frankly speaking, you have to live with it as it has been an unresolved issue from Bajaj. Nonetheless, you can report it to them and install a better gaskit along with a sealant to prevent the leakage. This, however, is not recommended as it would unnecessarily require your cylinder?s opening up and chances are ripe that the issue might still not get rectified.
Issue No 5: My bike leaks oil from the gearbox.
I can see oil drops on the frame and on the ground just below the gearbox.
This leakage is not actually from the gearbox but from the Neutral Switch and is caused by an inappropriate sized small round rubber sealing. This issue was more predominant on the first batches of 220s and has been rectified.
Solution:
a) In case your bike suffers from this leakage, all you need to do is take the stock small rubber ring out from the neutral ring and install a fatter appropriate sized one (available with Bajaj now). In case you are visiting the authorized service center, do not settle for sealants, tapes, coverings which generally are the solutions which they provide.
:cheer2: If in case, your neutral switch is running dry and you still see oil drops, there is one more opening for the oil after removing the crankcase.
However, counter check before opening up your machine that it is the engine oil which you see. More often than not it would be the chain lube or chain spray that gets spilled onto it.
Issue No 6: My main stand touches the ground on every bump
Again, this should have been taken care by Bajaj but sadly the height of the main stand makes it a little dangerous especially for those who are corner cravers.
a) Not an approved or authorized solution but you can go to a roadside mechanic and seek his help in this matter. A little raise is possible from the stock hanging position.
:focus: For people who love cornering, it is highly recommended that you remove the main stand when you go for a stunting session as it is one major issue for many accidents.
Issue No 7: Whenever I start my bike I hear a bad ?khrr khrr? sound as if some electricals are misbehaving
Solution: Check if it is coming from the starter motor. If yes, get the starter motor changed.
Issue No 8: Nothing happens if I push the starter button multiple times.
This is a safety feature your bike comes equipped with. After 3 back to back cranks, it disengages to save your starter motor and battery for some time. It is advised you give proper time before each re-crank.
Issue No 9: I cannot see anything through those rear view mirrors
Well, the Rear View Mirrors installed on the new Pulsar 220 DTSi are slightly bigger than the ones on the DTSFi. However, they are as worthless as well.
Workaround:
1) You can install RVMs from Apache RTR which have a bigger rod and wider viewspan of the back
2) You can also unscrew the stock ones tighten them to a slightly higher tread which would give you an extra tread or two of height (viewing space). But remember, they would go loose sooner than at the stock position. You will have to tighten them frequently.
3) You can also weld mirrors from other bikes which have a bigger and wider span like Pulsar 135 or Fazer on the stock rod of 220s.
Issue No. 10: Rear brake doesn?t have good stopping power
Whenever you report this issue to Bajajs people, their patented answer would be ?The rear brakes are intentionally kept with lower stopping power to prevent rear tire locking?. This is not absolutely wrong but unfortunately not completely true as well. 220s rear braking is not as good as some other bikes laden with rear disc brakes provide.
Workaround: Change your disc setup to the latest Bybre?s. Remember to change the complete kit and not only the calipers which Bajaj people will advertise!
Issue No 11: Rear brakes produce screeching sound?.
Many owners have registered this complaint and sometimes the sound becomes irritating. This was because of a little fault with the stock rear KBX calipers.
Solution: Change your disc setup to Bybre?s and remember to change the complete setup with calipers, disc pads, oil box, pipe and disc.
Issue No 12: My steering feels heavy and unnatural
Solution: It might be an issue with the cone-set. Get it verified and changed in case it has become the culprit.
Issue No 13: Sometimes, my bike?s engine goes off while I am riding and comes to life upon restarting after a little while. In between it doesn?t start. Also, this becomes more frequent while riding upwards (or in any particular motion)
This is one issue which the service center guys fail to detect properly.
Solution: If you are facing a similar issue and are exhausted of all other service center provided means, just get your carburetor float needle free. Better if you overhaul your carburetor.
Issue No 14: My bike returns a fuel efficiency of only 28kmpl under sane driving
A healthy pulsar 220 must return fuel efficiency in the range of 32-38kmpl at least.
Solution: Check if you are running rich on the air-fuel ratio (AFR). Set your AFR to the optimum position. This could be done by altering the AFR screw on the carburetor. Best is to keep it at its stock position.
Issue No 15: I hear a continuous tik tik sound from the engine and my performance is also not at par with other Pulsars
Solution: Take your bike to the service center and ask him to tighten your bike?s tappets.
Issue No 16: My bike doesn?t go over 120kmph
A healthy 220 should reach over 140kmph on the speedo easily.
Solution: In case it doesn?t than get your bike tuned properly. Do not set it for performance or mileage. Keep an optimum balance between the two.
Issue No 17: My engine is very harsh and it is hard to change gears
Solution: Switch to good quality semi synthetic or synthetic oils which would reduce vibrations from your bike and would improve the overall characteristics of the bike including the gear change feel.
Finally, just take proper care of your bike, service it regularly at authorized service stations, use good quality engine oil and rest assured it would keep you flying to places. This article is dedicated to Pulsar 220 and we are planning for such articles on other bikes as well. Do not forget to leave comments in case you liked, disliked or benefitted from this article so that it would propel us to better our future endeavors.
Pick up a ride and rewrite yourself to a new Identity....
#2 suman.stanley
suman.stanley
  • 11 posts
Posted 20 February 2011 - 12:33 AM
Your info is good and benificial for the 220 owners.. but it would be more interactive with some pictures of the related issues..if not all pictures at least those which can be.. will do even more better..
#3 ch.madhur
ch.madhur
  • 244 posts
Posted 20 February 2011 - 08:33 AM
i will try to add some pics there, give me some time.
#4 razorBlades
Posted 21 February 2011 - 04:43 PM
Great info there.. thanks for sharing!
BTW how do we check the bike's alignment?
#5 rdna
rdna
  • 5 posts
Posted 26 April 2011 - 03:21 PM
This is indeed very useful to the P220 owners. I own a RTR(1 year old) and it would be great to see something like this by someone who has owned it for a long time.. Thanks for contributing.
#6 v.v.shyam
v.v.shyam
  • 143 posts
Posted 14 May 2011 - 08:06 AM
DIY method or Professional method ?
DIY : is Nazar Andaz
Venkat Shyam,BV
Motorep
Bangalore
Auto Service
Bangalore
Email :v.v.shyam@gmail.com
IIMB mail :venkat.shyambv@alumni.iimb.ernet.in
(M): +91 9243 00 3337
#7 FordZ
FordZ
  • 1 posts
Posted 02 November 2012 - 10:32 AM
thanks.... more power pulsarians
