6 replies to this topic
#1
Posted 08 January 2012 - 11:53 AM
Description
TC 81 is specially designed to protect metal parts from corrosion. This provides good protection
against humidity and marine atmosphere.
Application
This can be used for the protection of all types of metal components. The film is moisture resistant
& gives long time protection.
Advantages
An excellent product for the corrosion protection of multi metals under humid conditions.
Pack size
500 ml aerosol can
Please Click the link to make the purchase
http://cgi.ebay.in/w...4#ht_3025wt_699
Shop Link:
http://stores.ebay.in/Tc-Lubes
Purchases or Query, please
Email:downshift2@live.com
Phone:8147410145
Our other products of Tribocor:
Chain Lube Bike Chain Spray ( TC 40) 500 Ml
http://www.ebay.in/i...7#ht_3506wt_968
Heavy Duty Cleaner Spray TC 28 (Chain Cleaner)
http://www.ebay.in/i...8#ht_2186wt_906
Super Lube Spray (TC 205) 500ML
http://www.ebay.in/i...8#ht_2420wt_906
Electrical Cleaner Spray (TC 22) 500ML
http://www.ebay.in/i...=item27d238cd50
Omni Spray TC 20 ( Anti Rust)500 ML
http://www.ebay.in/i...=item27d238ca5a
2 in One Spray Tc 83 (500 Ml)
http://www.ebay.in/i...a#ht_2237wt_906
Carburetor Cleaner (Tc 25) 500 Ml
http://www.ebay.in/i...=item27d238cdbe
Battery Terminal Spray (Tc 29) 500 Ml
http://www.ebay.in/i...3#ht_2048wt_906
Chain lube Tc 40 +Chain Cleaner TC 28
http://www.ebay.in/i...=item27d238cb31
Chain Lube+ Chain Cleaner+ Anti Rust
http://www.ebay.in/i...=item27d238cca7
Heavy Duty Cleaner+Omni Spray
http://www.ebay.in/i...6#ht_2817wt_906
Tribocor Auto Lube Grease (Tc 101) 1 Kg
http://www.ebay.in/i...c#ht_2168wt_906
Application
Advantages
Pack size
500 ml aerosol can
Shop Link:
Phone:8147410145
#2
Posted 10 January 2012 - 11:35 AM
Can it be used for bikes...any applications that you can think of?
#3
Posted 10 January 2012 - 12:48 PM
many a times non painted parts like nuts do get corroded.. So this i have heard is a good solution to it..
#4
Posted 10 January 2012 - 04:44 PM
Is there some solvent for it if we need to remove it after application? For example, to repaint the surface.
#5
Posted 21 January 2012 - 01:33 PM
Yes you can use it on metal parts.If you want to remove it, you can use tc28 which is a cleaner or degreaser.
Yes there is a spray called TC28 which is a cleaner or degreaser.You can see the details by clicking the link.
#6
Posted 20 July 2012 - 12:06 PM
#7
Posted 28 August 2012 - 08:39 PM
maverick1, on 20 July 2012 - 12:06 PM, said:
does it also adds shine i.e. acts like wax ?
The corrosion protection spray
You can use it to protect your mag wheels of your bike and handle bars
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
