Cbr250R 1 Year 25000Km Review
Honda CBR250R review 25000km long term review CBR250R expenses 1 year experience one year experience CBR250R issues
12 replies to this topic
#1 arn
Posted 02 May 2012 - 03:02 PM
The bike in question will complete one year on a couple of days. It has 25000km on the clock, though the actual mileage is somewhere in the tune of 26500km, for reasons I’ll go over later.
This was one of the first batch sold in India, and it did have some cosmetic issues such as poor plating, not so good paint job, rattly body panels, etc, but all these have been fixed now and first batch owners have had the “defective “ parts replaced FOC. So, lets get moving with how the thing has behaved since it was bought one year back.
BODYWORK
Once the rattles are taken care of, there is no further “music”. The only irritation is the fact that a lot of things need to removed to get access to the internals, but maybe that is Honda’s way of theft proofing things. There was at least one fastener socket which came with a stripped thread (rear right belly pan, fixed under guarantee). A mentioned before, anything with poor plating/paint damage has been replaced. Other small quality issue items – footpeg rubber.
SEAT
Stock seat is OK for the city, somewhat inadequate for the highway (much too hard) hopeless for broken roads. Padding it is not difficult (easy fix).
ENGINE + DRIVETRAIN
The NO PROBLEM bike. Still on the stock clutch, 1.5L oil every 6000km. It feels much the same after and just before the service. No difference. Does not show any sign of overheating even when run at 115kph+ on a sustained basis. Amazing engine. Lovely, slick box. Topped up coolant once, at 18K km
HANDLING
No vices, but the broad tyres do not like low friction surfaces such as steel drain covers, slush etc.
SERVICE COSTS
It’s Rs 750. That only includes washing, a little greasing and setting and chain tightening, apart from changing the oil and oil filter. If your valves need to be set, that is also included. Does not include chain oiling which almost costs ½ can of chain lube. If you are not changing shims and using their synthetic oil, expect the service to set you back somewhere in the tune of2300 bucks. Personally, next time I need to go in for a service, I’ll just do the oil and filter change (using my own oil), as the rest (chain lube + washing) is not a big deal and neither is greasing, and enter it in the service record. Service only when there is valve checking required as then, there is some specialized work involved. Air filter – just 200
OTHER SPENDS
Broken mirror (cheap – 400), Head bearings, changed at 18000km, one set of brake pads (fr + rear), after about 15000km. Damaged footpeg rubber – TVS 180 direct fit. Broken indicator – 300 (you have to buy the full assembly). One set tyres.Till date, 4 oil filters and three air filter elements (around 2000). 200 to reconnect a poorly fitted spark plug (courtesy Venetian Honda) out of town, in an emergency. Two chains (one pulsar 220), + one front sprocket (about 2K)
EXTRA SPENDS
H4 HID 4500K, Extra horns, tank guards, wiring for same + chain oiler. Approx 5000/-. HH sintered brake pads (about 2K), teflon 1/8n brake tube with stainless steel coil on it  (2K). 35T rear sprocket (WBS), costing about 2K. However, this throws the odometer reading off by about 8%, that’s why the disparity in actual mileage and odo readings. Seat, about 1K
ISSUES
I’m calling these as issues as there is a difference between issues and problems, one of magnitude. For me the bike has NO problems.
  • Availability of parts. Very disappointing in the beginning, still not good. This is still a PROBLEM
  • Engine rattle at 5 -6K rpm, at low throttle openings. No explanation. Valve setting reduces it, does not eliminate it.
  • OE brakes good, but not great. Huge difference with HH pads and non expanding line.
  • Soft front end, excessively so (especially now that the brakes are much better).
  • Some very incompetent mechanics, there is still a shortage of trained people. This is a PROBLEM, forces me to ride 30km for a service.
  • Side indicators leak, all of them, and fog up in the rains.
  • Headlamp had a weird setting, with all bulb filaments positioned away from the focal spot, hence bad beam pattern. I think this is a bike specific problem, have sorted it out.
  • El cheapo toolkit. Chuck it away. Med kit only to comply with legislation. Chuck that away too. Buy tools and a proper med kit.
  • For touring the tank is too small.
  • Poor wind protection unless tucked in. This is not realistic on the highway.
SO, would I recommend the bike?
YES
#2 Silver Phantom
Posted 02 May 2012 - 03:32 PM
YES
Oh So Very Very Like the Review :clap2: .. But doesnt change the Fact that i am gonna have to fight it out with my Budget + Wife + Other Priorities :frusty: ... So very gonna loot a Bank..... :evil:
#3 L.P.
L.P.
    Nitin Gupta - Photoworks
  • 213 posts
Posted 03 May 2012 - 04:19 AM
Tank small? - KTM's then? :P
ToolKit and Medical kit - Good one's
WindBlast even on CBR, whats the use of so much fairing then :(
:P
"There is Nothing, Forever, Except the Change"
#4 rahul_rn
Posted 03 May 2012 - 11:30 AM
Yes, why don't you donate yours then...?? :P
I guess compared to doc's older bike it might feel more..
The bodywork is what kept me second guessing when it came to cbr.. But since that has been solved the only thing that will be poking out will be service costs i guess.. But still even i am
to get my hands on this.. :D
p.s. anyone have a clue whether a more powerful cbr coming..?? Had read somewhere they are planning and since i know Honda i am guessing they will as most of their products are in two variants one a decent steed and other a more powerful one..
#5 pulsurge
Posted 03 May 2012 - 12:08 PM
You didnt see Doc's bike....it has no fairing :D BTW windblast is there but I find it more towards the upper body. A decent touring screen will solve the issue.
#6 Silver Phantom
Posted 03 May 2012 - 12:17 PM
A Variable Angle Visor should Solve the Problem..
Greater Angle for Touring, so the wind shall pass over the Helmet in an Upright Positon
Smaller Angle For Crouch Racing.. So the overall resistance shall be low..
Might Require fabricating a seperate frame to mount the visor, and the frame itself shall be mounted on Hinges / Levers to change the position.. Rubber / Flexible Bladder to fit between the Fixed and movable parts to avoid air leakage into unwanted parts.
#7 pulsurge
Posted 03 May 2012 - 01:49 PM
There are double-bubble screens readily available for the CBR...prob is they are too expensive :(
#8 spinz
spinz
  • 80 posts
Posted 03 May 2012 - 02:25 PM
Is this it?
#9 arn
Posted 03 May 2012 - 02:47 PM
It's been doing the rounds since some time. Maybe next year, if that. Still just a rumour.
Introducing a bike already in production elsewhere can be done in a few months (like the 150R), a new platform is a different ball game.
#10 parimal1981
parimal1981
  • 51 posts
Posted 04 May 2012 - 06:56 AM
View Postspinz, on 03 May 2012 - 02:25 PM, said:
Is this it?
Spinz,
The below is the one. Available in India as well.
Regards
Parimal
#11 parimal1981
parimal1981
  • 51 posts
Posted 04 May 2012 - 11:42 AM
View Postparimal1981, on 04 May 2012 - 06:56 AM, said:
Spinz -my bad. I thought the posted pic was for aftermarket windscreen. Turned out it was for a bigger cbr . Although it looks more like a well done photoshop  work to me on cbr 250 made to look like cbr 400
Regards
Parimal
#12 Guest_jennysmith_*
Guest_jennysmith_*
  • Guests
Posted 18 May 2012 - 02:50 PM
I  have cbr250r...it gives mileage of 32kms...i have touched 132 speed and it will go more than that...and it is super and fulfilled my heart.....  I love my bike ......
#13 drakelouis29
drakelouis29
  • 10 posts
Posted 11 June 2012 - 12:44 PM
i loved your bike it also seems to be in great condition, but also cant change the fact it will have some issues. i thing which i wanted to ask that is the warranty renewed? and why are you interested to sell it when its so good. also the mileage of the bike is little bit low can i know the reason because i heard that it gives average of 35 kmpl.
Also tagged with Honda CBR250R, review, 25000km, long term review, CBR250R expenses, 1 year experience, one year, experience, CBR250R issues
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
