Using Picasa
The direct link of picasa (http://picasaweb.google.com/home) or if you are in Gmail checking mails, click on Photos link present on the top.
1. Click Upload to put your images online
2. This will open up a window which will show the list of existing albums if any & Click "Select Album". Else you can create a new album. This will be a kind of folder to classify the images within.
3. Create Album window will now show up like this, type the descriptions if you wish & then click "Continue"
4. Now the page will show up where you can upload your images from your computer. You can upload as many you want. If you want to upload more than 5 images, upload first five images, Click "Upload" then you can repeat the above process.
5. Once the images are uploaded, it will be shown on the Page online now something like this.
6. Now how to insert this image into your Motoroid thread/topic. Click on the image which you want to put in Motoroid forum. This will enlarge the image, something like this .
7. Now, we need to copy the path of this image where it is present online.
a.) If you are using Internet Explorer, right click on this & click on properties
b.) A properties window will come up, need to copy the Address (URL) from this window, which is basically the path.
c.) This is for the users using Mozilla Firefox browser. Its simple here, just right click & Click "Copy Image Location"
8. Now lets insert this path in the Motoroid post. While you are typing the message, lets assume if you want to write something & want the image to display right below that. So type some text & click on "Insert Image" button something like this.
9. A box will show up asking for the online path. Now paste the path which we have copied from earlier steps & click "OK"
10. The image is now right along with your text
11. To check & confirm, click on "Preview Post" and Voila.. You have your image right there below your text.
This narrates a Step-By-Step process to insert image in your post using Picasa. Uploading from other sites is much simpler, Just the benefit of using Picasa is, you can archive your images into albums & keep it for future or share with others permanently.
Using TinyPic:
should be a similar process .
1. On opening the site (TinyPic), you will see an immediate window to upload the image. No login required.
Browse the image from the local computer & click "Upload Now"
2. On completion of Upload Process following window will show up which has all the information required. Copy the "Direct Link for Layouts" content which consist the path we require & you can put in your Motoroid posts from the above process narrated.
Hope this tutorial was helpful & should be easy for members who dont have much technical knowledge to upload the images the way they wanted.
Note : You can upload the images in your Motoroids Profile Album as well & insert the image using above steps.
