I have used several chain lubricants; SAE 90 Oil, Motul Chain Lube, the OKS Chain Spray and the Paras Chain Spray used at many Probiking centers but found the Paras Spray and OKS to be the best.
Of all my bikes, the R15 probably consumes or needs more attention as far as Chain Lube is concerned. The last few weeks had caused havoc with the chain as the chain was squeaking louder than a battalion of a thousand hungry mice. Add to that the typical rust and grime.
The 220 is much better at managing the lube but extremely bad at keeping it within. A spray lube results in a dirty rear wheel with splatter almost everywhere.
I happened to buy the TVS Chain Spray as a pure alternative to the Motul Chain Spray (not available at that time) and OKS (Dealer not known).
The Chain Spray retails for Rs. 295 in a spray bottle weighing 375 gm and contains 500 ml of lubricant.
Both the R15 and the 220 got the chain lube treatment and I found the performance to be good even after riding the bikes in rain and mud. The lube did not wear off like the Motul Chain Lube. The splatter is less and the lube feels at par with OKS and the Paras Spray.
My Verdict: Worth a buy...especially if you ride a lot. At Rs. 295, its a bargain.
Some pictures of the product
The Spray Can
USP
Content and Packaging Information
Usage Indicator
